I purchased a small house just over a year ago. The property is sat on a concrete slab, wood frame, built in the mid 90's approx 1,200sq ft. Did all the usual before buying.. hired a home inspector, had a friend look at it, had a pest control guy check it, AC company checked it, Roofer checked it out, electrical was checked.. all gave it the OK. I probably went overboard there but didn't want to screw up buying my first house.
I've since found I have an active termite infestation. First signs were a swarm breaking through the bathroom wall about half way up. I hired a pest control professional, gave him some swamer samples and he confirmed it was subterranean termites. He found additional evidence of termite damage almost all the way around the outside of the house. Wood siding low to the ground was showing signs of being soft and hollow. No signs were found that the termites had breached further into the house other than the swarm.
I hired a pest company which came highly recommended by friends to treat the property. $600 later they put 65 gallons of "Termidor" into the ground around the house and foundation. Drilled into the concrete in front and rear of the house to treat those areas too. The pest controller was 100% sure this will kill off all termites eating my house with 90 days and would kill the first within 3 days.
Is termidor as good as claimed? My concern is how much damage have they already done. I've found soft spots low down almost all the way around. In addition I've found soft spots on the lopped siding in the front of the house where there's a small bay window. Those soft spots go up to the top of the window frame. Other than this termidor and the monitoring stakes I put in the ground what else can be done to control or check for damage short of tearing walls apart.
