Hello,
New member here-I’m gut renovating a cabin in the lower Catskills in New York State. Lots of good information here.
I’d like to set up temporary power for house renovation similar to the spec attached from Central Hudson with a 60 amp panel at the meter post with a couple of outlets. I’d like to use a 200 amp meter so I can later transfer from the 60 amp temp panel to a permanent interior 200 amp panel.
My question is there any issue with running 4/0 SE cable to the 200 amp meter and use 4 or 6 gauge from the line side of the meter to the 60 amp panel. I’m not sure if this is ok to downsize the wire at the load side of the meter or if I need to run 4/0 out of the meter to some kind of disconnect in between the meter and the small panel.
Thanks
Thanks
