1 - 6 of 6 Posts
I have a coffee table that needs glass. I called a few glass shops and was told I could use regular glass over tempered. But the guy I brought the tables from said to use tempered glass because it was stronger. I need more knowledgeable answers on what is the proper glass to use for these living room tables.
Use tempered glass it is regularly used in applications in which standard glass could pose a potential danger. Tempered glass is four to five times stronger than standard glass and does not break into sharp shards when it fails. Tempered glass is manufactured through a process of extreme heating and rapid cooling, making it harder than normal glass. Use it and be safe.
· Too Short? Cut it Again!
Agreed. But how thick is the glass? Tempered glass may be overkill unless you have kids or a temper prone to breaking it. It is safer and easier to clean up if it breaks for sure. It will no cost you that much more.
What did you mean by using regular glass over tempered? I would not layer glass for a table top just for aesthetic reasons to start.
Ok two sides to this coin.
1) If the glass you’re using is ½’’ or ¾’’ thick than the top does not need to be tempered.
2) If you’re using ¼’’ or 3/8’’ thick then the glass has to be tempered.
So to answer your question, the standard table top is usually 3/8’’ thick and it should be tempered
· Learning by Doing
Didn't someone on the forum make a big glass picnic table? Was it DM or SD? I always get those two jokers mixed up..... Just kidding. there's a thread about glass tables around here somewhere.
1 - 6 of 6 Posts
