1 - 6 of 6 Posts
Hi everyone! - Is there any minimum temperature requirement for MIXING (not applying) modified/unmodified thinset? Is it OK to mix thinset outdoor where temperature is zero C then apply it indoor where temperature is 23C? Thanks for your responses.
Retired Moderator
Are you talking about mixing mud out doors in the winter?
No problem---just bring the mud inside before it freezes----add some details to your question,please---
Just to add something -
I ran into an "Old" tile-setter a number of years ago.
I got to work on the same houses he was working.
We discussed tile work a lot.
It was winter and he was mixing thinset in the garage.
He said, basically, the same thing that "oh'mike" said.
Also, he said don't use "Hot" water - use cool water (clean)!
something concerning the chemical reaction that goes on when you add
the water to the thinset.
rossfingal
Retired Moderator
Accidentally mixing the mud with warm or hot water is a huge mistake---Been there--never want to go there again!!!!
Tileguy
The products should be kept with a temperature of mid-range, maybe 55 to 90 degrees Fahrenheit. Tile installation must be kept above 55 degrees Fahrenheit. Mixing the thinset in extreme temperatures probably isn't the best idea. Cold water mixing will slightly slow an other wise normal process of curing. Warm or hot water mixing will accelerate the curing process and in some cases render the product unusable in a matter of minutes.
1 - 6 of 6 Posts
