Fermentation Chamber Wiring Help PID w/ SSR Heat & Cooling
Please assist me with AGPtek PID TA4-SSR wiring. I've searched high and low for a wiring diagram but cannot find one for what I am trying to accomplish. I want the unit to switch a cooler (True GDM49) and personal heater (200W) on and off. I could take the easy route and wire a STC1000 to the coolers stat but don't want the cooler running constantly. The unit draws 10 amps when running with compressor. I am not sure what it pulls when the compressor is not running.
The object of this build is to wire a True GDM 49 cooler into a SSR to PID as a fermentation chamber and a small heater to an SSR to PID as well. I want to use the compressor as the cooling unit portion and a 200W personal heater to raise the temp as/if needed. The temperatures needed range from 40*F to 80*F for fermentation depending on yeast strain. I want to ensure I have this correct.
I will also be using a K Type temperature sensor in water to monitor temperatures. It has a red and blue wire. The sensor will be used to measure liquid temperature, not ambient air. Yeast added to wort relies on certain liquid temperatures. The ambient air temp may be different from a liquid temperature in the cooler.
Thanks in advance for any and all help. If I had hair I'd be pulling it out.
Wiring of PID TA4-SSR:
1. Live 120v (black)
2. Neutral 120v (white)
3. Goes to 3+ on SSR #1
4. Goes to 4- on SSR #1
5. Goes to 3+ on SSR #2
6. Goes to 4- on SSR #2
7. Red K type temperature sensor?
8. Red K type temperature sensor?
9-12 not used?
SSR #1 for cooler:
1. Live from wall
2. Live to cooler
3. From 3+ of PID
4. From 4- of PID
SSR #2 for small 200W personal heater:
1. Live from wall
2. Live to heater
3. From 5+ of PID
4. From 6- of PID
Here is what I came up with:
9-12 not used?
SSR #1 for cooler:
1. Live from wall
2. Live to cooler
3. From 3+ of PID
4. From 4- of PID
1. Live from wall
2. Live to heater
3. From 5+ of PID
4. From 6- of PID
