Hello,
I was trying to diagnose if my A/C system is running optimally or not, and thought a good place to start would be to check difference between return and supply air temperatures.
I was able to get into attic and drill two holes, first hole right before air enters the blower, and the second is at where air leaves the evaporator coil. Figure these holes would also help for static pressure drop readings in the future.
Any HVAC experts here tell me what I should expect in terms of temperatures differences at these two points?
Also, is it better to do this test at return and supply registers?
Thanks for your kind advice
Gas Furnace : Bryant 310AAV PSC 3/4HP
Evap Coil: ADP HD-Series 5-Ton
Mount : Horizontal Left
Single story Home
Single story Home
