I understand some of the basics about what the numbers mean. But then there are things like fine finish tips. What is a fine finish tip and where do you use them? So where do you use what tips?
Like spraying a wall or ceiling inside a room?
A door?
Floor base trim and door and window casing?
Exterior brick walls?
Exterior wood on a house?
A fence?
Etc.?
Just want to get an idea of where what tips are used?
When do you want to use a 511 over a 513 or a 515 or a 517? They're all a 10" wide spray pattern but what makes you pick one over the other? I understand the last two numbers are orifice size and the bigger the number the more paint it will spray. But not sure when or why you would choose one over the other?
Another thing is how do you clean your tips and store them?
A door?
A fence?
Etc.?
