I have a stubbed in bathroom in the basement, not finished yet, but planning on it soon. we are going to add a kitchen area in the basement but i need to create a drain for the sink/dishwasher...
the good thing, the shower pipe that is in the floor, ill measure and add photos tomorrow, i think it was a 3" maybe, but yes its the one for shower that they surround with gravel to allow you the room to put in the jtrap or whatever that goes under the tub/shower.
what i was hoping to do is remove the rock/sand around that pipe (i already kinda did to the point where i can see the pipe hit a 90 and head over horizontally) but i still have some more removal to do. I dont believe there is any kind of a j trap there currently, pretty sure anyway... but i want to cut that pipe down low enough to add in one of the t connections that will still allow it to come straight up to make a connection for a shower, but then also run over horizontally only about 3 foot to where it will hit a framed wall where the sink will back up against and i can use it for a drain.
My main question is, since i have to have 1/4" per foot of drop for drainage, and i want the new drain to be 2", if i can fit a t of some kind in there and still keep it below the basement floor level so a shower can still be installed there, i was afraid would i still be able to keep the pipe slowly inclining towards its new kitchen sink location, i was just afraid that where it came out of the new T, it might be perfectly horizontal to the floor, would the pipe be flexible enough i could still "force it" to move uphill at that 1/4" per foot without a problem, im guessing i can but still need to be able to do this and have room for the jtrap for the shower and keep it all below floor level. the reason im picking the shower drain as it is very close to the wall where the sink drain will be and i would have to remove very little concrete to move the pipe across"under" the floor to get it there, the toilet drain is a few feet further away but technically still accessible, or do i need to tap into this pipe that is under the floor but putting the T on the actual horizontal piece of pipe. just to be sure im clear, i am suggesting cutting the veritcal pipe that is coming up for the shower to a shorter length, and putting the T on the verical "riser" part..as there just maybe be enough room, ill tell exact measurements tomorrow, but its like a foot or so of play i have before it hits the 90 and cuts over under the floor. or im wondering do i have to cut the whole riser off and put a T onto the main horizontal line that runs under the floor and have a new riser come up for the shower from the new T and then run my new drain off of the opposite side of the T from the main line that is under the floor already. hopefully the measurements and pictures tomorrow will clear up anything i wasnt clear on
** from the picture the wall the sink is going to be on is the wall right straight back, pretty close to straight back from the pipe or maybe left a touch when looking at the photo, as far as venting, i would vent in that wall in the back of the picture where the drain would be, and run the vent up and connect into the vent that is already waiting to be tapped into that they left for me in the basement joists when they stubbed in the bathroom for the basement
