HI,
I use tapcons for any work where I might want to change it later, i.e. a temporary wall in the basement, temp shelves, etc. They are very easy to remove.
I have a problem with the tapcons in my home I have never had before. They keep snaping off when I drive them in. They are Tapcon brand name. I've tried the larger 1/4" tapcons. Many of these are only around 2" tapcons. I am positive I am using the correct size bit and drilling more than deep enough(extra 1/2" to 1" deeper than the Tapcon). When drilling the hole I pull the drill / bit in and out a couple times to make sure I get the dust out. Yet, even if I use a drill with a clutch on it, the tapcon just snaps off in the hole once it is about 3/4 of the way in.
This has happened to me maybe 20-30 times now in my basement with Tapcons from multiple batches. I was putting up a 4x4 electrical box,and wanted 2 tapcons in it to hold it in place. The I broke of 5 tapcons in that box before I finally drilled a larger hole and used a zamac.
I get the feeling that my concrete was a high stregenth pour from how hard it is to dril into, even with a Hilte Te5. There is metal wire / rerod in this pour.
I've resorted to using Zamacs or the Nail type anchors you pound in. But to remove those you have to use a disk grinder.
Has anyone ever had this problem with the Tapcons? Is there a solution? Prior to working with tapcons at my house, I thought tapcons were really strong can can't ever remember having one break.
Thanks
Jamie
Thanks
Jamie
