Hey all, I have a quick question. It sounds reasonable to me but I want to check with the experts first :thumbup:
I may be investing in a plumbable espresso machine that also has a drain.
There will also be a water filter + softener in the line, and obviously requires some minor plumbing on my part.
I first thought that I would just pierce into some cold water pipe with an ice-machine kit, but then realized the washer is RIGHT behind the wall where the espresso machine will sit. Does it sound reasonable to you all to splice into the cold water line at the washer to feed the espresso machine?
Also, I was thinking I could even drain to the washer, but on second thought the drain inlet may be too high up to allow for this. I may end up draining into the crawlspace "well" using pvc unless anyone has a suggestion for this.
And just one final question about aesthetics. I know if I were to install a water inlet for a washing machine they have the nice recessed cold/hot water + drain setups. (http://bit.ly/TTpxGN). Is there something like this that I could use for my purposes? I'm a bit hesitant to set up the water line like a toilet would be set up.
Thanks for any suggestions!
