anyone, I'm looking for easiest way to attach miter bars (rockler) to the sled,I've tried many ways but just doesn't seem to work, any suggestions will help because video's just don't spend much time on how to attach miter bars:vs_mad:
yes, the rockler bars are 18" Im ok using 1 bar but when I add the 2nd bar it tends to not freely slide , so my pre-They have 1/4-20 tapped holes in them, right ? Use 1/4-20 flat head machine screws.
I used my own steel bar, not Rockler. But I cut a slot (dado) about 1" wide in the sled. Then wedged the bar tight against one side of the table saw, with some paper shims, to make sure the bar was straight. Them put a bead of PL Premium on the bar and put the sled on top and let it set. Then I filled the 1/8" gap on either side of the bar with Bondo filler to lock the bar in place -- can not move.
Going to be very hard to get two bars perfectly in-line. I used my table saw miter slot to hold my one bar straight. If you got a big saw, you can do that too. If your saw's table top is not long enough, you can hold the bars in-line with one or two spirit levels.yes, the rockler bars are 18" Im ok using 1 bar but when I add the 2nd bar it tends to not freely slide , so my pre-drilling must be off since I have to put the screws in from top down
