1 - 18 of 18 Posts
Hello to All,
I've debated for a long time on getting a new table saw, but the time has come if I can find one that is cost-effective.
Live in West Houston, but I have a table saw at our small ranch 55 miles west of Hou. It has a metal stand [non-collapsing], a heavy duty metal top and a motor that weighs a ton [Rockwell 1970's model]. It requires 2 people to move it plus it is real heavy on one side. Bottom-line, need something more portable for using at home.
Do not need a commercial style t-saw, but something that rips plywood well and can rip angled cuts too for making trim. I have a nice compound Miter Saw to assist. Also,. I'm 6'4" so something that can maybe adjust upward.
If you have any questions, pls let me know and thank you very much for your experience and advice.
Thank you very much,
tstex
I too have large cabinet saw (Powermatic PM2000), but also a Bosch 4100 for a portable use. It's an amazing saw and the gravity rise stand is much nicer than Ridgid's or Dewalt's (both of which I also own). It's not equivalent to a big cast iron saw, but it's proven capable of everything I've asked of it, including 3/4" dadoes in hardwood.
I recommend adding both extending supports and a zero clearance insert. If you're doing a lot of angles on it, you'll probably also want to upgrade the miter gauge.
· Jack of all - master none
I recently purchased a Bosch GTS1031 to replace my huge saw. It's very, very portable. Although the saw cuts well and has a ton more power than my circa 1970s Craftsman, I'm not sure I would recommend any of the portable table saws out there for ripping plywood. Unless you are building it into a large stationary cabinet, they just are a little too risky to try to shove an 8' sheet through. Better option would be to get a nice circular saw and a straight-edge (or a track saw) if you need to do portable cutting of large sheets.
Here's the saw all folded up into its compact storage space:
EDIT: Also, if anyone has a Bosch 4100 and wants to purchase the extensions for it, I accidentally bought them thinking they would also fit the 1031. They do not. I also mistakenly purchased the dado insert for a 4100 and have that. The restocking & shipping fee was so high that I just decided to keep all of it instead of send it back. PM me if interested.
Thanks to all for your suggestions.
If I used rollers and had help w me, would this change your mind on using a portable to cut plywood?
· Retired Moderator
Rollers move and tip over--if you MUST use a portable saw for cutting plywood--
Use a table behind the saw---adjusted to the same height as the saw top---
If you can also have support on the left side of the saw table----I have seen home made tables that have a cut out for the saw---
I've never used that Bosch saw--but it sure looks like a nice one.
Discussion Starter · #9 ·
quote for "oh Mike"
"If you can also have support on the left side of the saw table----I have seen home made tables that have a cut out for the saw---"
Thanks Mike - do you have a pic of the cut-outs?
I imagine Mike is talking something like this picture. They can come in any shape and size you imagine. You just need a space to set the saw so that the top is level with the rest of the table. Obviously, the downside of this is it takes up a lot of space, which is why most people purchase compact saws to begin with.
The other problem with cutting full sheets on a portable saw, is most do not extend their fence very far. DeWalt's new line goes to 24", but many can't rip a sheet in half with the fence they come with.
· World's Tallest Midget
Mafell Erika when I win the Powerball.
Before that, you may look into a track saw for breaking down plywood. Much easier to move the saw than that heavy sheet of wood. Makita and Festool make good enough cuts that you don't need to clean them up on a table saw afterwards.
http://www.buzzillions.com/reviews/craftsman-professional-15-amp-10-portable-table-saw-21829-reviews
http://www.rockler.com/kreg-rip-cut-circular-saw-guide
The table saw is the one I own. Love it. Folds sown to get our of the way in the garage. I use the Kregg guide to break down plywood and I am very satisfied with the results. If I need to cut a 4X8 into (2) 4x4's I have a hardwood 2"X2" that has been planed straight and has clamps to hold it to a sheet of plywood to use as a straight edge just for that purpose.
Discussion Starter · #16 ·
Great info guys - really appreciate all the feedback.
I'm also going to need to rip some milled pine boards I had made when a person in the country cut down about 14-16 pines that had 2+ft diameters. The dimensions on those vary from 12-14" W x 10-16'ft L x 1-2" H I always have someone w me when I do this: one on the receiving end and one on the giving/pushing end. I always use sharp blades. I can use the 70's 200Lb Rockwell table saw for this.
The one I'm looking for here in the City is to cut plywood to make more garage shelving and add'i walking space in the attic [plywood over rafters].
Thanks again for all your experience/advice, it's invaluable. tstex
If you are cutting plywood to make shelves then use the Kregg guide. I have a 15 amp Skil Circular saw that the guide mounts to very easily. The set-up will allow you to cut up to cut 24" wide pieces. I can zip through 1" plywood very quickly. There are internet pages that will show you how to make your own, but I like the Kregg guides the best.
· Retired Moderator
Just a tip----Home Depot will rip plywood for free----if they have what you need---
When I need to cut ply on my portable table saw--I will frequently get the material ripped at the Depot---then do the final sizing on the job---no extra cost---and mighty handy.
1 - 18 of 18 Posts
