My furnace (gas) has C G Y W R
for controls.
Stat itself (digital) has Y RC RH (jumper in place on rh an rc) W G C H2 H1
what I would like to do is use the "cool" function of the thermostat to strictly start the blower. I have no "cooling" in place, I just would like to run the blower on the t-stats "cool" cycle to help circulate the air.
any input?
thanks in advance.
Tin
for controls.
another question, on the furnace circuit board, what two control leads do I "jump" to start the blower?
any input?
thanks in advance.
Tin
If I'm understanding you correctly, you shouldn't have to do anything. On any call, cool or heat, the thermostat should put 24 volts on the G wire, this is the wire to the furnace that turns on the fan.
Just hook your 5 wires to the same terminals on the new thermostat. R goes to both RC and RH on the stat.
Jumping R and G at the furnace should turn on the fan.
Most thermostat will energize both Y and G when calling for cooling, so you should not need to do anything other than verify your G thermostat wire runs to the air handler's G terminal.
Let us know if that doesn't work, and please post make and model of thermostat.
Thank you everyone.
I did get the blower to run.
Thank you.
I need to understand for myself, so I will learn more.
I am very thankful for the help. I will now try and learn more of what's going on, and don't be surprised if I come back with some questions.
thanks again.
