So I have 1 power source coming into the switch. That is going to be a single pole switch going to a celing fan. I will also have another switch in a different box controlling another celling fan, which will also be a 3 way switch just for light part. I want a separate switch for fan control in the same box (double gang). I will also need to bring power to another switch (separate box) single pole for another switch. What will this diagram look like?
It seems that this post has four separate requests: -
1. I have 1 power source coming into the switch. That is going to be a single pole switch going to a ceiling fan.
2. I will also have another switch in a different box controlling another ceiling fan, which will also be a 3 way switch just for light part.
3. I want a separate switch for fan control in the same box (double gang).
4. I will also need to bring power to another switch (separate box) single pole for another switch.
While I do not have the "skills" to post such diagrams, I believe that I may have the "skill" to break down your request to its components, so I will just answer as follows:-
1. Wire the Line and Neutral of the fan to Line and Neutral of the supply, with a switch in the Line.
2. The switch for the light will be one of a "normal" pair of of 2-way (US usage - 3-way) SPDT switches.
3. Presuming it is the "same box" as for "2", just install it as for "1"
4. To say that you "also need to bring power to another switch (separate box) for another switch." is confusing. "Please explain!"
