HI,
Here is my issue at my home. I have a light switch which controls the recess lighting in the living room as well as all the plugs. A pretty poor design IMO especially since that room also acts as the TV/entertainment room. As of now I have to use an extension cord to the next room to use the always hot plug so I can watch TV when I want the lights off. The plug I would like to use in the circuit has two wires coming in, each with a ground, white, and black wire. In my research I thought I found a solution where I could break the metal tab between the two plugs in the socket. When I opened everything up, it doesn't seem to match what I researched so here I am asking the experts. I have attached 4 photos of the plug. 1 showing the inside of the box; 1 for each side showing each tab(on the black wire side, the tab is still there connecting the two, but it's covered with a piece of plastic so it looks like it's separate); 1 for the back of the plug. I have included pictures of the only switch. Seems three wires go to the switch, each containing a white, black and ground wire.
I would be fine with one plug in that socket being always hot, and the other controlled by the switch; whichever is easier.
Thanks!
Thanks!
