1 - 7 of 7 Posts
I added a switched outlet in my house and I followed the schematic in this image: https://www.google.com/search?q=3+w...=chrome-mobile&ie=UTF-8#imgrc=B0N0VyDcWJwKVM:
The switch and wiring is working as expected, but when the switch is off, there is 48VAC at the outlet according to my multimeter. I checked ground, neutral and hot connections and everything is nice and tight. Is the 48V indicative of a bad switch or is something else wrong?
Super Moderator
plug a lamp in and then check voltage.
Discussion Starter #4
Got the neutral from an existing lighting circuit. Didn't disconnect switch from outlet, but I think I would have got the same result at the switch with the outlet disconnected.
The reason I think I would have got the same measurement is because my meter was creating a voltage divider with the switch. I did plug a lamp into the outlet and tested the voltage in parallel. With the lamp as a load, I got mV reading for off and 120VAC for on.
I believe the 40ish volts I was reading was due to voltage divider between my meter and the switch. After doing some quick research it looks like people get confused like I did when using a DVM.
I think I'm set. Thanks for the help!
Super Moderator
Did you use the same hot as the lighting circuit that you used the neutral from?
It was most likely capacitive coupling between the hot wire and the switched wire that was part of the voltage divider along with your meter.
Discussion Starter #7
Yes I did use the same hot for that neutral. I can see that if I didn't do this is get weird measurements. But it seems like if get those weird magenta even with the lamp in.
1 - 7 of 7 Posts
