I have a problem with a switch that I am replacing. I was in the process of replacing a switch that feeds a single light in a bedroom. When I pulled the old switch I found that the previous owners had spliced into the hotleg by simply making a couple tight turns and a few wraps of electrical tape. I discounted it and found out that it feeds three outlets. Now I know that the splice is definitely not up to code. My question is a remedy to this. Can I tie the outlets into the incoming hotleg and leave a pigtail to go to the switch? Any recommendations would be greatly appreciated.
Super Moderator
Cut the single tail off at the end of the twist.
Strip the cut end and add it the two existing twisted blacks with a wire nut.
Wire as it was before.
Discussion Starter #3
Thanks for the reply. That's what I did. Just wasn't sure if there was a better way or if it was a major no-no
