switch on raspberry pi
1145 Views 6 Replies 7 Participants Last post by  bradleyshome
I wish to add a fan to my pi along with a on/off switch and a power light how do I do this ?
1 - 7 of 7 Posts
I give up, what's a raspberry pi?
Going to need way more info.
Had to look it up also. Apparently it is some sort to teaching computer
https://en.wikipedia.org/wiki/Raspberry_Pi
Depends how big your enclosure case is that you're using. Often the 'Pi' is used without one.
If your transformer is located near electric outlet, then your cable is supplying DC to unit. Leave it alone and solder your new lighted switch after that point. After that, solder in your fan wires. Maybe glue each to case?
There are many R Pi forums that can recommend parts and suppliers.
You could either modify from transformer to microSUB or throw a switch on receptacle.
Here's my PI running KODI playing WTV files from NAS & 4tb drive on router.
If you're powering your Pi from the wall, try a lamp switch designed to go on the cord.
Adding a power LED should be pretty easy. The "hello world" samples for Arduino and Pi are turning on an LED. Any of the Pi sites will tell you how to do that.
Not the best forum to ask this when there are dedicated rasberryPi forums haha :)
https://www.raspberrypi.org/forums/
1 - 7 of 7 Posts
