Electrical Pros--
Having some challenges with some light switches... Main issue, one switch, we have no idea what it turns on/off... My guess is it is a secondary switch if we installed a ceiling fan out on our patio... I took some readings from the switches with the switch both on and off... I have attached those readings in the attachment... Most are normal, but a couple seem suspect (maybe not, I have no idea)...
Second, I was supposed to have pool equipment pre-wiring accomplished when they built the home... I do have a one-gang box with 12 awg which looks like it runs from a switch (right next to the trio of switches above), but there seems to be no power to the switch and/or wires in box outside... I've attached a copy of the electrical build plan for my house where it shows the switch (inside), the box (outside) and a separate pre-wire for a pool heater... There is nothing on my exterior wall that would indicate where this pre-wiring was located... Any ideas???
Thanks much,
Roger Vrooman
Thanks much,
Roger Vrooman
