Why make the change?
Why make the change?My idea is to switch a currently 120v 20amp breaker to a 240v 20amp breaker
I dont understand what you said there. let me give an example:AllanJ said:Note that sustained (continuous) loads such as heaters or air conditioners should not more more than 80% of the breaker rating; use the next size up if needed.
He is saying that a load such as this should be more than 80% of a circuit.I dont understand what you said there. let me give an example:
Your logic is completely wrong. Two 25A fuses do NOT make a 50A circuit.The condensing unit needs 50 amps. I install a 60 amp disconnect with 2 25 amp fuses in it. at the panel, the circut feeding the a/c is connected to a 60 amp breaker?
Ah, and there she is. I found what appears to be the main breaker box outside directly behind what i though was the main. First glance inside the box leaves me wondering where the actual main switch is? Is it the giant leaver seen on the right that seems to disconnect the two one time fuses? any thoughts?That is a main lug panel the main breaker or disconnect switch should be directely behind that panel otherwise you will have to follow the conduit where it goes { typically found below the meter socket }
Second thing if you going to use one of the exsting conductor or cable for 240 volt circuit you double check make sure there is nothing else on that circuit otherwise you will see magic smoke real quick.
The safest and wisest methold is run a new circuit and be done with it.
As far for breaker size for your A/C unit it will depending on what type of unit you will install that will affect the rating.
Merci,
Marc
