Not a handyman here, so here goes...
I took a swinging door off the family restaurant/bar to sand it down and repaint it, as it was getting very gross. It seemed easy enough to take down, just six screws, right? Well the three screws that held each hinge to the door were holding a hinge that had the force of a rat trap...no...tiger trap! Once I got to the final screw and began loosening it, the hinge snapped shut, destroying the screw. With the help of a couple others, we removed the screw. But as far as putting the door back up (probably Thursday or so) I am worried. The piece/plate with the three holes in it (where the screws will go through and into the side of the door) is resting on the hinge body. I've tried putting a thin blade in between to pull out that plate (shown by the red arrow) but the force is pretty great. Is there an easy (or easIER) way to pull this plate out when the time comes to put the door back on? Or am I going to have to find some thin blade strong enough to pry it up and then use my scrawny fingers to hold it back while someone else screws the door in?
I've attached a photo...it may or may not make this any clearer!
