I had a regular switch for my dining room- I took a picture of it as I was installing my dimmer switch. See the attached photo.
After installing the dimmer switch the dining rook light with dimming abilities is working just fine..... EXCEPT!!! that when the new dining room dimmer switch is in the ON position the kitchen lights that are apparently on the same line do not work. If I turn OFF the dimmer switch the kitchen lights work as normal.
Any ideas?
the new switch had FOUR wires ==a red wire with white stripes, a ground wire, a red wire and a black wire.
I did NOT touch the existing connection of all the connected white wires in the box. In the box there are three grey wires going to the existing switch and one of them was on a screw.(photo) and of course there is a ground wire-- I hooked up the red wire with the white stripe on the new switch to the grey wire that was attached to the screw-- I assume that was the common wire and the other two grey wires I hooked to the black and red wires on the new switch. (also connected ground wire )
Did I buy the wrong switch? Did I do it wrong?
I am just a homeowner but too embarrassed to call a handyman to do such a small job. this should be easy ( or I thought)
Any ideas?
