Hey everyone. I've got a Square D QO 200 amp plug on neutral panel and would like to put a surge protector in it.
I see that Square D makes a QO surge protector that simply plugs in with no pigtail.
Here is my question: my panel is technically a sub panel, as the main shutoff for the house is on the back of the house by the meter. Therefore my ground and neutral are separated in the panel. Do any of you happen to know if that plug on neutral surge protector would function properly if used in this situation? My concern is that the surge protector needs to go to ground, and I'm not sure it would function properly in a panel where the ground and neutral are separated in the panel.
The ground and neutral are bonded at the main shutoff on the back of the house, with a ground wire that comes inside to the ground bar in the panel. There is another ground wire where the power comes up out of the ground just before the meter, and that ground wire goes to the ground rod. The house is a duplex where the power comes up from the ground splits to left and right, with a ground wire and rod basically in the middle.
Thanks for any thoughts.
