Power came back on after power outage. I have a DVD that no longer works and a garage door opener both on separate circuits. The circuit breaker was not tripped and using a lamp ( without a ground) I had power at the opener. I also had power to a nearby GFCI on same circuit. When the garage door service man replaced the circuit board and plugged the unit into the outlet there was a pop and the breaker tripped. The plug for the opener also had slight (arc ) damage to both the hot and neutral prongs. Where and what am I looking for to fix this?
