Hi everyone, I am new here but this looks like a great place to ask.
Short version, I want to terminate a short 15' run of mini french drain (with 2" perf pipe) into a shallow gravel hole right behind a retaining wall. There is a legit french drain with pipe at the base of the retaining wall, as is proper. I want my new pipe/drain then drain down into the wall and eventually into the real french drain. Bad idea, or okay?
Here is the longer version with details, pictures attached.
I have a retaining wall that is near my front patio. There is one small section of land between the retaining wall and patio, about 28" wide and 6 feet long, that tends to take on water coming off the patio, which has created some negative backflow toward the house foundation (see photos). I have filled the spot with paver base to create positive drainage away from the house there, but I am considering installing a small mini-french drain to better conduct water coming off the patio there further away from the house and to the back side face of the retaining wall, about 15 feet away.
I plan to use 2" PVC perf pipe (since the area I am trying to drain is actually small), but my main concern is how it terminates. My current plan-- which I am unsure about and therefore am seeking advice-- is to bring that pipe to the back side of the retaining wall, and have it terminate in a shallow gravel-filled hole right behind the wall, with the hope that it drains into the hole and down into the wall itself. There is a real french drain at the base/backside of the retaining wall so any water going down into the wall and behind the wall eventually go to that drain, where it exits the base of the wall from a "daylight" pipe.
Am I crazy to think that just ending this short 15' run of 2" perf pipe (that will be in a shallow/small french drain trench w/ gravel) in a gravel hole behind the retaining wall is a workable plan?
Planning to do this today and tomorrow so any advice is very much appreciated. THANK YOU!
