In an old (110 years) home I recently purchased I found that the 2x8 joists that have been severely compromised by a bathroom remodel done a few years ago (first picture with gouge on the top of the joist). A friend's suggestion was to run ("sister"?) a 2x4 along the bottom half of the 2x8. I don't think a 2x4 will fit above the PVC pipe, so I was also thinking of putting some 1" plywood - say maybe 2"x48" - along the top side of the joist to strengthen right where the gouge is. See my proposed diagram.
Further down on the same joist are 2 big pipes going through the center of the joist. The holes take up approximately 1/3 of the width of the board, as seen in the photo. Is this problematic? I have a clawfoot tub basically directly above, so the amount of load here will be very high.
Besides these place where significant portions of the joist have been carved out, is there any general reason to add supports? The same friend said that adding 2x8 blocks perpendicular to the joists is not helpful because, at this point, the joists don't sag any further than they've already sagged.
One idea I'd been mulling over was to run run 2x4s along the bottom sides of each joist and adjust them so that the bottoms of the 2x4s were level. I was thinking that this would both add strength and help with the drywall later. To be clear, the bottom of the joist and the 2x4 would be the same height at the bottom of the sag in the ceiling. Near the edges of the room, where the joists are not sagging at all, the 2x4s would be lower than the joists. Does that explanation make sense? See diagram.
All of this is preventive. Nothing is broken, just trying to make things strong while I have access to it and before anything might happen.
