Do the rafters have mechanical fasteners that attach them to the walls, other than a few nails?
Have you tried jacking up the center of one yet?
Thanks for that. The 4x6 beams (rafters) rest on the top plates of the garage walls. The 2x6 decking is nailed to the beams. And yes, I jacked up one of the beams (in the center of the span) and was able to raise it about an inch which eliminated the pond when I sprayed with water. Need to jack up at least three, if not four of the beams and then figure out a way to hold them so they don't sag again. The garage is 25 feet long. Hope that answers your question.
Yes agree, even a small slope can help.I don't think so. Seems like sandwiching the existing beams with more appropriately sized material will provide what should have been there in the first place. At least that's what I think. I guess we will see. Hopefully for sure it will eliminate the drain in the center of the garage put there by the previous owner. Flat roofs shouldn't be flat!!:smile:
I have heard of putting a board under the joist and thought it to be a good idea. Have you done it.The most bang for your buck would be to glue and nail a 2x6 to the bottom of your beams. Get a basement jack, glue the beam then put 2x6 under and jack up beam until just past level (or build a beam and do several at once, if you have helpers). Then nail to ensure good glue contact, glue is what's actually doing the work. You'll gain more support for less money than sistering.
Reason for this is that all the support is done by compression and tension at the top and bottom of a joist, when you sister you're only adding 1.5" of max tension/comp material, and as you move towards the center of the joist it does exponentially less. When you glue to bottom chord you utilize almost all the material at max leverage to resist tension forces.
See chart here - https://www.decks.com/how-to/40/beam-span-chart-table Going from a double 2x6 to a 2x8 gains you 26" of span with only 2x3" of wood added, tripling up that 2x6 only gains you 15" of span.
So, adding mass below rather than to the side give you 43% more span and uses 28% less wood. Just butt up to walls of course, no need to set on plate. Just another option, either way works, I've done both.
Edit, also that roof should have a slope built into it with iso foam when it's reroofed, either towards a drain or to the outside of roof.
