I have a house that the previous owner installed two 4"X6" posts under the second story sub floor that hold the main support beam for the second floor of my two story house. These two posts are in the middle of my garage supporting the beam that runs from the back of my house to the front of my house between both garage doors.
The beam will be 19'8" from wall to wall.
As you can see from the pictures I did make a home made beam thinking it would be strong enough. This beam is still in place but it still flex's to much and I ended up leaving one of the 4"X6" posts under it to help hold the second floor (which is my living room)
My question is.. I want to remove the existing home made beam and buy a 14"X22lbpf I beam and install that bad boy. How do I beef the 14" beam up so it is stronger? I need a diagram.
My engineer here at work said to Zig Zaz some 1/4" plate thats the same width of one side of the flanges in an up and down pattern about 4 feet long along the beam both sides with gussets in between.
Like this: |/|\|/|\|/| ok I know thats a cheap example but will this work?
I was thinking of welding in some 2" pipe in a X pattern about every 3 feet along both sides of the flanges.
Is the 14" overkill? its only 200 bucks from my metal supply company.
Thanks
Mick
Galveston/Houston Tx
Thanks
Mick
