Hello,
I want to mount a 17' wide motorized sunsetter awning to my two story brick home over a patio. I am confused about the instructions. My home was built in 1961 and looking at the brick it is one layer of brick so I am assuming this is still considered "vernier" and I should not mount the awning directly to the brick. Is this true? They give you two lag bolts, 4" top and 5" bottom and say to drill into the center of the brick. My concern is will this hold the awning. I am guessing the brick is like 3-4" thick and has a 1" gap between it and the wall behind but not sure. The awning weighs about 140 Ilbs and will have 6 brackets holding it on the wall. Does anyone have any experience that would be helpful? It would be much appreciated. I have a picture I can post of the area to mount the awning. I am planning to mount it about 9' above the patio which is at ground floor level.
Thank you,
John Z.
Thank you,
John Z.
