I have a sunken living room that drops approximately 11 3/4" to the lower foundation. This is where the existing drywall stopped, and carpet was glued to the foundation wall and covered with trim where it meets the drywall. The existing drywall is not flush with the foundation but overhangs from 1/2" in some areas to almost flush with the foundation wall. I've pulled the floor carpet and the wall carpet off to install wood flooring. First Option is to install 1/4" drywall and mud up so it blends with existing drywall and and match texture. The flush areas would just be mud and texture. Second option is to install 1/2" plywood (cut to size) to foundation wall, and add trim where it meets existing drywall and add baseboard at the bottom. Concerns: I heard the mud may crack, is that certain? Will it be reliable? How would the wood be attached? Liquid Nails? Work will be contracted out. I hope this isnt confusing..
Thanks...
Thanks...
