Hello - we need to update our sump pump, so had a contractor come and take a look.
He noted that the water level in the sump is well about the drain tile inputs by the time the pump kicks in. When the pump triggers and the level goes below those inputs, the flow into the sump is substantial until the level goes above those inputs, and then it seems to slow down again.
But he made a claim that the water level in the drain tiles could be much higher than in the sump. That sounds like nonsense to me: when the sump is filling slowly, it's almost a hydrostatic situation, and the water level is very nearly the same throughout the system.
Also, his solution is to do ~$1100 worth of work to extend the sump pit down about 14 inches, which sounds pretty disruptive to our finished basement.
Question 1: is his claim about the higher water level in the drain tile suspect?
Question 2: Are there other solutions besides extending the sump pit? For example, changing pump on/off limits?
Many thanks,
Pat
Many thanks,
Pat
