SO much easyer to picture what you have with a real picture.
The washer is the primary issue here. Washer dumps into sump, sump pump eventually forces it up and out, and sure enough the sudsy washer water is what you see in the tub. It only pushes a little bit up, but still...Option 4: Run the sump pump discharge out independently to a dry well.
I'm assuming the ejector pump that serves the washing machine doesn't cause any of these issues?
I hear ya, man. I'm just doing what I can to work through the issues of it. I've seen some houses where in the basement, the outbound waste drain pipe is on the floor. This one, however, is at eye level when I'm standing down here. I guess since they knew they'd need a lift system for the sink, they figured using the sump pump made sense. Or... something like that?Ah...got it. It's an ugly set up all around.
Well, I wouldn't doubt the derailment thought. We're the second owners of this house and we moved in back in January. They however lived here since it was built in 1958.It sounds like the previous owners train of thought derailed a long time ago. By washer I guess you mean clothes washer? That is not suppose to dump into your sump pump. Do you have a Septic Tank or are you connected to a City Sewer. Some people dont like dumping detergent and bleach into their septic tank for fear of killing the bugs, but my whole neighborhood is on septic and evryones washer dump into their septic system here.
Yeah sometimes you just gotta rip crap out. We bought a foreclosure with a mix of corroded copper, galv, and illegal PVC supplies. Repiping was a lot of work, but it was The Right Thing To Do and we'll enjoy the benefits for for many years.Give your wife break
judging by the improper use of fittings and unsupported pipe you may want to get a real plumber in there to straighten things out
I'm just using the terms that were presented to me during the inspection. This situation has several different angles, though. The washing machine and sink need to go into the sewer system. Okay, fine... I can get a hose extension and likely hook it up to the sewer pipe along the ceiling. But the sink on the other hand... I have to figure out some way to get the water from the sink to "lift" up to that point. I think that's why they just opted to put the sink/washer in the sump pump since it was just easier (even if it may not have been entirely correct). Hmm...The sink and the washing machine should be piped into the sanitary sewer system which you said was a city sewer system. They have to be properly trapped and vented. The sump pump basically receives rain water from around the footers, and can be pumped out of the basement, usually onto a slash block.
Your term drain field is applicable to a septic system. Its important to use the correct terms if you wish to be understood.
