Hello all. I have been researching for the last two weeks about how to best keep water from pooling in my crawl space after a big rain. I live in Little Rock Arkansas and this year we have gotten more rain then usua. In fact its been about 16 years since we had this much rain. I bought this house in January and it was built in the '60's. Not sure how long this water has been an issue, but I would assume for awhile.
After all this research I have learned I know nothing about french drains, and I use to install them for a living. I need some advice and someone to say Im either crazy or I am heading in the right direction. Please help.
So my house sits on a slope, slope is from west to east with a pretty decent grade. The west side of my house is built on a pad, while the east side is on pier and beam. I feel that the water is going under the slab and then arriving in my crawl space where I pump out with a sump pump when it rains. When it is not raining there is no standing or pooling water in the crawl space.
What I want to do is put a french drain on the west side of the house a foot or so before the slab. See pic of WestSideWhere.... jpg for trench already dug. Now mind you I did not dig this out, my buddy came over and dug it while I was away, but I can't complain it was free. So in that trench I want to do a french drain with sea ballast as my rock and 4 inch pvc 2 holed, with a sump pump at the furthest end (about 70 feet of trench). At the nearest end I want to put a water basin that will be fed by a concrete ditch (more or less, I am going to dig a small trench then outline it with concrete and have it dump into the basin which will then filter into the trench.
From the farthest end where the sump pump will go, I have a previous french drain pipe the past owner put in that I want to run a 1 1/2 inch schedule 40 pipe through, then under the furtherest part of the fence and eventually down the hill another 100-130 feet which is where a garden will be and the water will either filter into garden or one day into a holding tank for future use in the garden. The total run from sump pump to where I want water to go is probably 200-250 feet. From the pump it would go uphill about 70 feet then the rest would all be downhill.
This is the only way to get this water to a lower spot. In the photo at the closest point all that is behind is uphill, and a driveway to the east. So the sump pump would be at the end of the ditch where it would have to make one 90 degree turn to head north towards the fence. My questions are:
1) How big of a pump should I use?
2) How far can I expect a pump to pump? Is over 200 feet too far?
3) How deep should I drop the pump down?
4) What should I encase the pump in. I found some 12 inch in diameter round cylinders that are about 12 inches tall as well, will they work?
5)Will or should I just grade the trench, drop a few inches of rock on top of the weed fabric, then pipe, then more rock and then fold the fabric over with more rock on top? I was going to do rock all the way up with no dirt on top.
6) Suggestion on type of pump (brand).
7) Do I need a sock fabric to put over the 4 inch pvc?
Ok, I have added two extra pictures just for a reference. The back yard one is from my deck which is looking east, to the right would be south. The other is from the northeast side of the property. Just gives an example of the slope. I actually own the two properties east of this one where the house sits where I want to do the french drain. The property next to me is empty, and the one after that my dad lives in the house. I have other drainage that will go in front yard that will be piped towards the empty property and eventually to the crib where I will knock out the curb and drain into street.
Ok I know that is a lot of info, but I just can't seem to figure this out and I have a backhoe coming this Wednesday, and rock as well and I got to get the rest of the material bought so I am desperate. I just keep reading and reading and can't seem to find answers.
I appreciate any info that you can provide, and please allow me to say Happy Fathers Day to all you fathers out there. Thanks
Jack
Jack
