Hello experts!
Previous Owner set up sump pump with battery backup pump. There are a lot of cables: AC, batter power, backup switch, backup sensor. There's a lot of slack in most of these cables.
For some reason, PO put most of this slack inside the pump. That made a rat's nest of cable that leads to the float switch being trapped from above or below if any of the cables get moved by just a bit.
Is there any good reason to put the slack in the sump, and not on the floor surrounding it?
Thank you.
Previous owner most likely didn't like them visually lying around, but I agree why not just limit the inside to the mandatory ones and lessen the slack on the others outside the sump. I have two cables exiting my sump lid; the rest are adjoining the back up system neatly dealt with. Remember to get your back-up battery off the floor (piece of wood under it is sufficient) and to check it's function once in a while to ensure it's working. I find our 1 year old boat-like battery that came with the system gradually discharges over the months, even with adding distilled water and despite the indicator reading active.Most back up batteries are only good for 3 to 6 hours depending on rain volume/intensity. Enjoy your new home.
