Our crawlspace has a dehumidifier and sump pump and has the plastic wrapping on the walls. The company has gone out of business so can't call them to ask about what's going on.
The dehumidifier is running fine, and it has a PVC pipe that drain to a basin. The basin top looks bolted closed so I haven't tried to open that yet, but can if it would help diagnose things. There is an Intellishield pump control plugged in, and Google indicates that this turns the pump on when the water reaches a certain level. Then there is a battery backup system that looks just like this Myers MBSP-2:
Myers MBSP-2 - Classic Battery Backup Sump Pump System 600 GPH @ 10'
We are having problems with this battery backup. Every now and then (maybe once a year) it will start beeping that the batteries were no longer charging. This was either do to a major snow storm and we were out of power for several days (so of course it wasn't charging) or if the GFCI outlet tripped for some reason.
Lately, it's been alarming about once a week that it's not charging. When I crawl down there I just pull the power cord from the charger and plug it right back in and it switches to "charging." Hearing it beep through the kitchen floor and having to crawl down there is a real hassle. I think it's not the GFCI since the dehumidifier still runs and they use the same outlet
Any ideas what might be going on? It's been about 10 years so maybe the battery is no longer holding a charge, but I'm not sure why the battery pack would act this way. Maybe I just need a new battery pack? Or I'd be fine having it hardwired if that's an option. We only lose power for more than a few hours maybe once every year or two from a snow storm.
If more details or pictures would help, I can do that. Thanks!
