Hi, I'm hoping that the good people of this community can suggest a workable solution to my leaning fence
Half a year ago my neighbor and I build a new fence and took care to do the job properly (or so we thought) - the posts are 2 meters apart, each 70 cm down, and each hole got an entire bag of cement.
However, a week ago we had a pretty severe storm, and the wind blowing in from the empty lot next door managed to tilt the fence up to 20 degrees (estimate). Apparently the earth was still pretty soft, both from digging, and from the construction work taking place on the other side.
I have uploaded a few pictures showing the fence leaning, and the gaps on the inside of the fence where the earth has been displaced. (EDIT: apparently I'm not allowed to place either links or images in my first post, so you'll just to imagine it for now
Any suggestions how to fix this? Getting it back to vertical is easily doable, but the question is how to stop the same thing from happening when the winter storms start blowing? Eventually the empty lot will have some nice tall buildings screening from the wind, but that will likely take a year or two more.
I have thought of ramming some steel bars into the ground next to the posts, but I suspect the concrete will make that pretty difficult. I could of course do it midway between two posts, but that seems more like a band aid than a proper solution.
We could also try to dig down on the inside of each post and pour in additional concrete?
any comments are appreciated
