When we bought the house, my wife complained the stair rise is too high. Which I do agree. It is currently 8". And with the run being 7-7/8" (9" tread depth minus the 1-1/8" overhang), the slope is 45.91°. Every time I bring a big box or a basket of laundry downstair I'm worried of falling down. Going up is not as bad because it is an open stair.
As I'm finishing the basement, I wanted to rebuild the staircase, enclose it and add under stair storage.
The problem I'm running into this morning, is that even going by Ontario code limits, that floor opening is insufficient.
The floor opening is 230cm and floor thickness measured from top of finished floor to bottom of joist is 11" (28cm).
The headroom is required to be at least 195cm and is currently 196.5cm so I don't have a lot of leeway compared to the current bad stair slope.
Basement height is 235cm, with the upper floor thickness of 28cm, that makes a total rise of 263cm. The basement floor is not finished, we'll be going with laminate/vinyl planks.
With the floor opening serving as walls for living room, dining room and kitchen, I'm really stumped as for what I can do about it. Can I even reduce the joist ? It is 9", if it could be replaced with something else perhaps a metal beam I could gain a bit of height restriction. The problem is that it probably support the wall above it.
I calculated from omnicalculator.com, that using the code limits, I only have 185cm of headroom at the restriction point, which is 4" short, not including the drywall that need to be placed. So reducing from 9" joist to 5" beam... even if that is possible, would be quite the job, definitely not DIY and will cost how much ?
And keeping the stair as is, is not a solution as I need to add insulation to that cement wall as I'm finishing the basement so I need to rebuild narrower stairs. Can anything be done ?
I'm already forgetting about having comfortable staircase and concentrating on meeting code limits. We would have preferred a 10" or 11" tread depth.
