OK
I'm looking at building a wooden bed frame. What fasteners etc do y'all think will be good?
Size is Eastern King. I already have a thick pillow-top mattress sitting on double (side-by-side) 6" tall foundations. I want to raise this up off the floor, finally, and get 7" of clearance under the frame for bed storage boxes.
Yes, I know the bed will be up kinda high. We like it that way.
I have a CAD design using some doug fir 2x4 joists attached to fir 2x4 side rails. There will be three 1x12 hardwood boards making a skirt/rail around the outside (sides and foot), flush with the bottom of the frame and sticking up. So not only the twin foundations I already have are held in place, but also this skirt gives enough lip to encourage the mattress to stay in place as well.
There are 10.5" tall legs attached to the inside of the corners, top flush with this 2x4 frame. We want the legs inset from the corners instead of like a normal bed post, to save stubbing our toes. I'm thinking of using a couple of pieces of 2x4 attached at a right angle, then cut to make a triangle footprint (see the diagram). This is so that I can clad the legs with the falloff bits from the 8-foot-long 1 x 12 hardwood boards, so the color and/or stain of the legs matches the skirt. I don't have enough falloff if the legs are a rectangular profile, but with this triangle idea, I only need two 5.5" x 7" bits and one 6" x 7" bit for each leg.
Oh and also I have six 10.5" tall 2x4 legs holding up the middle of the middle joists as well. Overkill, or just enough?
I already have a separate headboard, and it will be attached to the wall, like in a hotel. Because reasons.
SO
Take a look at the diagrams. My questions, if y'all have ideas:
How should I attach this stuff together? What size screws/bolts? Placed where? Should I do the corners of the frame differently? Should I use the salvaged and good-condition deck joist hangers I happen already to have?
What is a good way to make this frame dis-assemblable for moving house? I'm not ready to move anytime soon, but I'm thinking ahead.
Any carpentry load-knowledge comments are helpful.
Thanks.
SO
Thanks.
