The back of the panel will be tied to the ground (so entire cabinet is grounded.) The neutral bar is what is completely isolated from ground in a sub.If you separate the neutrals from the grounds what happens if
the bare ground wire touches the back of the panel?
Or is the neutral bar that you remove the bonding screw from
to separate from the panel?
