I live in NJ in a town that follows NEC 2005 codes. I live in a ~1800square ft. house with 1 primary electric panel. Looking for planning help to prep for design and permit application.
I'm looking to install a new sub-panel (Square D QO 100A / 20 slots / with 100A main breaker) very close to the main panel and feeding it with a 100A breaker. Does feeding 100A to the sub-panel from a main panel that is only 100A cause any code violations?
I'm looking to move a 10-12 breakers off the main to the sub and then add in a breaker to feed in a generator using an interlock kit.
I've researched other items and plan on unbonding / keeping separate neutral from ground in the sub panel. Also using #3 THHN copper with #8 ground through PVC conduit between main and new sub-panel.
Any tips and help greatly appreciated!!
