Ok the details. First I'll say a professional will be doing the install I just need some clarification!
Some details
• Sub panel will be about 67 feet from meter
• Will need 100 amp panel for for a 60amp breaker, a 14 amp breaker and possibly a 20 amp or another 14 amp breaker if I decided to do some GFCI
• The 60 amp breaker will be for a 6-50 outlet in which my pottery kiln will be plugged into. I can't have anything else on that breaker but the kiln or it could affected firing.
I have 6-2 with ground UFB for the kiln. 14/2 for outlets and lights and then the wire for the GFCI (which have not been installed yet). My question is do I have to buy additional wire to connect the subpanel to the meter? I asked because he said something about size 4 wire and I really don't want to spend more money on heavy wire IF I don't have to. So having no idea how a subpanel is wired I just need to know what my options are? Like can the 3 wires I stated above be connected to the subpanel and then run to meter or are they connected to the subpanel and then an additional wire like a size 4 is ran to the meter? A professional will be doing the install I just want to know my options. My main concerns are that nothing else is on the breaker with the kiln and not having to buy additional wire if possible!
Some details
