what do you do if the neutral conductor on a subpanel feeder cable (awg3) is too large to fit in one of the free openings in the main panel's neutral bus - can you split the strands and run half into 1 of the screw connectors in the bus, and half into the another, or do you need to add a (larger) lug connector - if so, would this lug just clamp onto the existing bus?
thanks
-randy
Discussion Starter #5
thanks kctermite - it's now on my things-to-pick-up list on the way home tonite
feeling a little less clueless now... :blink:
