I have a 150 amp panel (that doesn't take tandem's). I have 3 slots left on my panel but I need at least 5 for some stuff that I'm adding. I was thinking about just adding a sub panel. For some reason they say 100 amp on the box but they only sell 60 amp breakers. Is 60 amp ok to use for the feeder? Also I really want to get a solar array some day. I suspect it would need a slot or two on the main panel. Does anyone have any insight on that? If so where should I leave the extra space, on the main or the sub?
Last question...Is sub panel a half ass way of doing it or should I be looking at replacing the whole panel with a 200 amp instead?
You can buy a 100 amp dbl pole breaker, for they do sale those for most brands. OR you can exchange the current panel bought for a 100 amp that already comes with the main. You will also need to purchase 100 amp service entry cable to subfeed from the primary panel to the new subpanel.
1) You will take the both hots insert one in each terminal on the 100 amp dbl pole
2) take your neutral insert that in the neutral side of the panel terminal.. AND same with your copper ground. Insert it in the ground terminal(if not shared with the ground) on the terminal side.
NOW:::: with current 100 amp you purchase(if setup for i believe it is), it comes with two line load sides above the bus. You will take one hot and insert it on the left side of the line.. then the other on the right side of the bus. Continue same principal with your neutral and copper ground wire. STILL you will install the 100 amp dbl pole in the main service panel.
