First question is the black bar my finger is pointing to needs to be removed for a subpanel correct? This will be where I intend to hook up all the white neutral wires
Second picture is showing that I have disconnected the bar from the neutral bar. My next issue is I tried removing the lug on the ground bar to completely remove the black bar. First I assume this bar needs to completely come out and 2nd the stupid cheap screw holding the lug on completely stripped; can I break the black bar off and leave a clean flush cut?
Next question is despite the ugly wire pattern do I have the wires correct? (I didn’t want to cut too much until I was 100% certain what to do) I assume on a subpanel all the neutral are connected to the neutral and all the grounds are on the ground bar
Sheathing will be cut down and wire routing I’m planning will make 90* turns to their respective locations.
Sorry for the photos not being vertical...I don't understand why photobucket is doing this...my subpanel is installed vertically
