I removed 3/8” laminated wood flooring from ¾” OSB subflooring. The glued areas damaged the surface of the subfloor where the glue beads were. I am installing ½” thick 3 ¼” wide engineered white oak plank flooring. The subfloor was not loose but I went ahead and rescrewed it to the floor trusses with deck screws. Do I need to install plywood underlayment. Is so could I get by with 3/8”? If I need it, how should it be fastened- screws into trusses, screws not into trusses, staples into trusses or staples outside of truss areas? Would rosin paper between the sheets be advised? I will use roofing felt under the new engineered wood. Thanks for sharing any experience with this.
