Hello, I've been reading previous posts and am now ready to ask my own questions. I understand from cclarlisle in a previous post that there are four acceptable methods of tile installation:
(a) with thinset, on two layers of 5/8" plywood, or
(b) with thinset, on one layer of 5/8" plywood and 1/2" CBU, or
(c) a 1.5" thick mortar bed+metal lath combination, or
(d) with thinset on one 5/8" layer of plywood plus an uncoupling membrane.
This is my floor - 2x10 joists, span of 12 feet, unknown wood type, probably spruce, old but in excellent condition - probably closer to a full 2". Spacing is 16oc. Above that is 5/8 plywood. I have screwed the plywood down every 4-6 inches. Tile will be Porcelain, 18X18. ONE HITCH: half the floor has very old tile linoleum, glued with mastic. It is EXTREMELY difficult to remove. Like nearly impossible. It is very thin - 1/8th maybe.
First question: There is ONE inexplicable soft spot. That one I screwed down every 2 inches. It still moves. The joists are strong - they do not move. I've stood under while large men walk above. Just the plywood flexes in one area - about 3x3. Assuming I do not put another layer of plywood down before tiling - how do I strengthen this spot?? - it is accessible from below.
Second question: I am a very experienced DIY. However a proper mud underlayment system seems more than I want to tackle, and a larger floor height than I want. I have exactly 1 " to spare. Is there any reason why, given my facts, I can't just put Ditra down and tile it?
Third question: Can I leave the old linoleum? ( I know you guys normally recommend removal).
Fourth & Fifth questions: If I put another layer of plywood (exterior grade), am I right that I do NOT screw to the joists? If I put this second layer of plywood (5/8ths), do you still recommend Ditra, or can I go without? Cost is a factor.
Phew! Oh! I forgot - can I get Ditra in Canada?
Thank you for any advice you can give me.
:yes: jtz
:yes: jtz
