Hello again all. After practicing on the small bathroom I'm finally doing the master. I feel like I know what I'm doing for the most part, but do have a few questions.
The shower will be 4'x6', and I'm doing a mortar pan, with a topical membrane and a linear flange drain at the wall. Right now the entire bathroom has a 1/2" subfloor with some thick cement board on top (it looks 3/4"). All the cement board will come out and be replaced with backer board.
The last time I did a mortar pan it had a center hole drain and sat on top a 3/4" subfloor. This new situation raises a couple questions for me:
1) I don't feel like 1/2" plywood is enough to set the pan on. Should I reinforce it with more plywood, or can I just use backboard along with the rest of the bathroom floor? Does it need to sit on wood so it can shift or will the backboard keep it from cracking?
2) Following the drain instructions for a topical membrane installation, the 3/4" thick drain sits on the subfloor. This makes my pan 3/4" thick at the drain. I usually feel comfortable following manufacturers instructions, but that's a lot thinner than the 1-1/4" minimum you get with a center hole drain. Am I okay, or should I slide a 1/2" board under the drain to make the pan thickness 1-1/4"?
Thanks!
CG
Thanks!
CG
