Hi!
I would like to have a 50A 240/120 sub-panel in my basement. There is a less than 40 feet run 2-conductor and ground wire cable there with the following print on it 6-6-8 Type SE cable Type XHHW CDRS 300V to ground E11134M (UL). Also, the ground wire that goes to my main panel is running very close by.
Question: for a sub-panel, can I run the 2 hot wires from my main panel on this cable and use the ground for return, or very much against NEC? The ground needs to be separate for a sub-panel, but as I said, running close by already.
Thanks for your help!
Mike
Mike
