I doubt anyone will be able to help on the internet, but I figure I'd post this up on the longshot that someone encountered something similar before.
I have 3 sets of recessed lights in my master bathroom that stopped working this morning. They are on the same breaker/circuit as two exhaust fan/light combos which are still working. I have a 3 gang box with the switches for the lights which are no longer getting power. I even fed the box from a nearby outlet and the lights worked like normal.
I figured it had something to do with the switches that control the other lights. I opened them up and noticed they backwired some of them and used the screws as well. I figured one of the switches went bad, but I connected the hot directly to the wire I believe feeds the recessed light switches and nothing happened.
I looked up in the attic and followed the wires as best as I could without pulling all the plywood and moving everything around. I noticed they laid some insulation over the romex with the paper touching and this started to burn/brown the paper. The lights still work when giving them power from the outlet so I don't think this is the culprit. Could the wire that feeds the recessed light have heated up enough to damage the wire?
I'm stumped. Unless there's a junction box up in the attic, but why wouldn't they just power from the light/fan switches over to the recessed light switches?
I'm sure this is futile, but if anyone has any ideas or advice, please chime in. If I can't figure this out the only other thing I could think of is to connect these lights to the outlet circuit. I guess I'll have to do some attic raiding before going to that extreme. Thanks for any help. I'm sure this doesn't make sense written out, but worth a shot.
