I am building a covered porch type structure. The one side is anchored off the back of the 2 story house using a 2x10 ledger board lagged into studs every 16". I have hangers 16" on center on that board. I have (4) 4x4 PT columns spaced 10' apart with a total distance of 30 or so feet. The distance from the ledger board to the 4x4 posts is 14'. The 14' "joists" will be 2x8 and tie into a 2x10 bolted onto the 4x4 posts. It will have a very light weight roof that will be sheeted with 1/2 ply. The ceiling will be t&g material. My question is if the 10' spaced 4x4s is sufficient for the load? thanks in advance,Pete
